OVERHEATING
Old Apr 10, 2006 | 10:05 PM
  #21
Tims 88GT's Avatar
Tims 88GT
Default RE: INTAKE OVERHEATING
in front of the #1 injector
Old Apr 10, 2006 | 10:08 PM
  #22
99mustang0's Avatar
99mustang0
Not to rob your thread, but i just put the gt40 upper and lower intake on and mine is running really hot all the time too. How would i check to see if somethings blocking any tubes?
Old Apr 10, 2006 | 10:10 PM
  #23
ikeybmg's Avatar
ikeybmg
if the sending unit is bad you should be able to unplug it. and if its bad, the fan will kick on when you unplug it.
Old Apr 10, 2006 | 10:11 PM
  #24
Tims 88GT's Avatar
Tims 88GT
^^ not if its a fox, are you guys sure the the t-stat is in right?
Old Apr 10, 2006 | 10:13 PM
  #25
ikeybmg's Avatar
ikeybmg
ooooh. i wasnt sure about the fox. it might be just for the sn95.
Old Apr 10, 2006 | 10:25 PM
  #26
Mthd11's Avatar
Mthd11
ORIGINAL: Derf00
3) place the thermostat in boiling water, it shoudl open. THen pull it out, it should close.
This man knows... This always works, and normally solves the overheating problems, well anytime I've ever recommended it, if it doesnt open buy a new themostat.
Old Apr 10, 2006 | 10:28 PM
  #27
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Maybe the car is running slower cuz the timing is set impropperly. Could also be causing the o/h'ing problem. When you say slower, how much?
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
