(My body work) decided to paint 1/4's
#21
RE: My body work
ORIGINAL: Tims 88GT
oh yea mike that is 800 grit, im going to take the 1/4 window out tomorrow, and do a final 1500 sand. primer than re-sand with 1500
Tim,Are you wet sanding it before you prime it?
#23
RE: My body work
ORIGINAL: Tims 88GT
oh yes, i dont sand unless its wet, all that was wet sanding. the only time i sand with it dry is if i have puddy built up and im using a heavy paper to shape it.
Yea i have dry sanded the whole car by hand,Now i am going to wet sand it all then comes primer...Im off tommrow for vacation for a week so im going to try to get everthing done,By the end of vacation..
#25
RE: My body work
ORIGINAL: Tims 88GT
what grit did u use when dry sanding?
I have been using 320grit, And i belive the disk for the sander are 200 grit
Im going to use 800 for wet sanding...Also tim are you sanding the ground effects?
#26
RE: My body work
orbital sander? are you taking the car to metal? do 800 sanding than a 1500. trust me if the body work is smooth the paint will look like glass im by no means a body man, but i do know a few things about body work, i like to get peoples oppions on it thoe.
#27
RE: My body work
orbital sander yes,No just the clear coat off,But i had some rust spots i had to take care of so ive been grinding them out primein then putty,sand over and over again i think i could do it with my eyes closed...I just wanted to make it really smooth so i sanded it with low grit and i planed on higher grid when i wet sanded it..
Are you sanding the ground effects?
#28
RE: My body work
i did all the ground effects last summer, dont use anything more than a 600grit on them. what you need to do with ur rust spots is a 320 grit sand, then a 800 sand, then epoxy primer, than sand 800 again, epoxy again, sand 800 and it should look nice. puddy only if u have to.
#30
RE: My body work
Tim are you going to paint your door? I think thats in more desperate need of a paint job then your quarter was. I guess I'll see the new paint job tomorrow.
Tim I think next week I might get started on my own paint job, I'm just not sure what to do about my right 1/4 where its banged in.
