throttle position sensor
Old Apr 11, 2006 | 09:22 PM
TMeyer29's Avatar
TMeyer29
Default throttle position sensor
alright Im going to try to install the tps myself...I know how to go about doing this but whats the idle voltage supposed to be at???
Old Apr 11, 2006 | 09:23 PM
ikeybmg's Avatar
ikeybmg
Default RE: tps
.98 or .99 with key on and car not running.
Old Apr 11, 2006 | 09:24 PM
TMeyer29's Avatar
TMeyer29
Default RE: throttle position sensor
that was quick thanks man
Old Apr 11, 2006 | 09:26 PM
5.0_faithful's Avatar
5.0_faithful
Default RE: tps
ORIGINAL: ikeybmg
I set mine right in the middle of that @ .985. Car responds quite well. You should periodically check the voltage though because the TPS tends to slip a little from vibration.
Old Apr 11, 2006 | 10:21 PM
TMeyer29's Avatar
TMeyer29
Default RE: tps
whats the easiest way to test the voltage???And how exactly do I adjust it.Im not too good with this eletrcal stuff
Old Apr 11, 2006 | 10:28 PM
TMeyer29's Avatar
TMeyer29
Default RE: tps
bump
Old Apr 11, 2006 | 10:32 PM
TMeyer29's Avatar
TMeyer29
Default RE: tps
nvm I found it on the internet
Old Apr 11, 2006 | 11:49 PM
TMeyer29's Avatar
TMeyer29
Default RE: tps
i got a reading of 53!...the same as the "broken" TPS,My engine light also still comes on.
Old Apr 11, 2006 | 11:50 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: tps
Where is your base idle set at. That will affect the reading. Did you alter that prior to having a problem?
Old Apr 11, 2006 | 11:51 PM
TMeyer29's Avatar
TMeyer29
Default RE: tps
do need to upgrade tps with a 70mm throttle body...The guy I bought it form upgraded the throttle body but left the stock tps on
