World Products - Windsor Jr. heads
#21
RE: World Products - Windsor Jr. heads
ORIGINAL: Tims 88GT
if ur going to cut pistons when u rebuild the motor, just run the stage 2 cam and 1.6rr
#23
it's a 5 spd with 3.55's (stock drive train right now) with a 750 carb and rpm intake. will the stage 2 and TW heads still kick it with my current setup, or will i have to get a vic jr intake to run the high lift cam??
#24
ORIGINAL: 88blackCONvert
I've looked around, but im kinda worried about buying a set of used heads that i can't inspect, know what i mean. I was just wondering if anyone had or are using the windsor jr's, and some real life results??
Just a little friendly help.
Also another friend of mine has WinJR's on his Capri and he is very happy with them. One thing that people tend to over look when it comes to heads is average airflow not the peak airflow. Who cares if it flows 290cfm @ .600" lift if you are using a B303 cam? You want to find flow figures that not only have been documented by the manufacturer but hopefully by an independant source. Here is an example of what I mean by average numbers.
Flow Numbers from MM&FF
#25
what kind of flywheel horsepower can a box stock 185cc head typically support N/A?
and good point capri, the very good low lift flow numbers are why I want a set of AFRs. they match anyone for peak flow, but outflow the competition at less than peak lift, which is very important.
#26
Thanks for the info man. I've since decided to save up for some TW heads from trickflow, and go with the stage 1 cam. It should be a good setup/step up from stock, and the windsor JR's.
#27
88 how much $$ you wanting to spend? Also if your around this weekend I will grab one of my procomp heads and let you take a look at it. I can prob. get you a set cheper than anyone else if you like them
I was thinking about getting a set of the Windsor Jr's (180cc) to slap on the ol' mustang. What do you guys think about these heads, and what cam would best compliment them? I like the price on them, so they are the front runners in my wallet so far.
#29
Well as much as TW heads will be a step up you shuld consider a few things. One is that with WinJR heads you can easily locate a set in the $500 range. You could use them for a year or 2 and still sell them for the same $500 you paid. Also, you would be making a switch to a stud roller rocker and that would mean you could use those on the TW heads too. Another thing you don't want to do is have a set of wind tunnel heads on a block that can't make use out of a cross breeze Read the MM&FF article that I posted from the AFR articles section. It's a long series and if you don't have broad band you'll wish you did but that 8-9 month issue series is unmatched in SBF head testing and information bar none. I just wish that it would include some other heads we have out now.
#30
ORIGINAL: Crump_4
