fuel regulater adjustment help
04-14-2006, 09:36 PM
RE: fuel regulater adjustment help
why would the fuel pressure be low when cold?
04-14-2006, 09:38 PM
I like the ruff idle! how can I get it to stay or should this kit idle smooth?
04-14-2006, 09:42 PM
The Rogue Mod
Quote:
ORIGINAL: 3stangs
You have a cam?
04-14-2006, 09:45 PM
yea it came with the kit.
04-14-2006, 09:47 PM
kit had heads, cam, upper and lower intake, roller rockers, rods , bolts, gaskets, timingchain.
04-14-2006, 09:48 PM
The Rogue Mod
Ok, so what's basically the problem. I must be missing something.
04-14-2006, 09:56 PM
cam-duration at .050" ---221"/225"
cam lift --.312/319
valve lift---.499/.510
lobe separation --112"
should this make my car idle ruff?
04-14-2006, 09:59 PM
car idles ruff when started but not after warming up. Could this be the cpu? Or should it be that way?
04-14-2006, 10:03 PM
The Rogue Mod
Quote:
ORIGINAL: 3stangs
No cam lope at all after warm up?
04-14-2006, 10:06 PM
not as much as start.
