Tim I'll drop my car off next week and you can paint mine. Are you still painting your car red. Also the duplicor sealer should work good if your using there primer.
ok so anything over 800 is for color sanding right?
Well you prep a cleared or single stage panel for blending or color with 800 and a gray 3M scuff pad.
500 is ffor prepping a jammed part or a panel that was repaired and needs to be completely painted.
The only thing over 800 that you'll use is 1000, 1500 and 2000 for wet sanding dust and hairs in the paints after it's cured, then buff it out. 1000 and 1500 are for bad runs and stuff in the clear...
OK I got ya. I would like to get somewhat good at body work so I can do it on the side sometimes. Zach for 5k ill paint ur car. Dunno what im doing color wise yet.
