Why does my A/C suck?
Old Apr 18, 2006 | 07:54 PM
blk95snake's Avatar
blk95snake
Default Why does my A/C suck?
My air conditioner is horrible. It blows cool air, but it doesn't get nearly cold enough to even bother turning it on. My 88gt had the same problem, is it just the 302s A/C that is crappy? My 98gt had freezing cold air. Is there anything I can do to make it colder without getting a new A/C unit?
Old Apr 18, 2006 | 07:56 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Why does my A/C suck?
pressure could just be low... you have an R-12 system which sucks because you HAVE to go to a shop to have them recharge it. You could get it converted to R-134A so you can do future servicing yourself.
Old Apr 18, 2006 | 07:59 PM
blk95snake's Avatar
blk95snake
ORIGINAL: Derf00
About how much does it cost to get it charged?
Old Apr 18, 2006 | 08:15 PM
marx91's Avatar
marx91
to get it converted it, i think it costs about $250, not sure
Old Apr 18, 2006 | 08:24 PM
5.0 MPG's Avatar
5.0 MPG
I converted mine and its been well worth the money. I had a couple small leaks and I was able to repair them myself and recharge the system for under $30 bucks.
Old Apr 18, 2006 | 08:48 PM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
r-12 is like..20 bucks a gallon i believe. in missouri it is anyways. I would defintaly convert to r-134 but you'll have to replace some stuff to do that. the reason 5.0 had leaks is because r134 is less dense than r12, making it lighter. the small leaks he had when he switch wouldnt have been noticible with r12. r134 is just able to seep out of smaller cracks and holes in the lines because its so less dense.
your ac probably isnt that cold because you need to get it charged. i'd take to a lube shop and have them do it. it shouldnt be too much.
Old Apr 18, 2006 | 09:24 PM
91lxstang's Avatar
91lxstang
my local shop told me 450 to convert.....
Old Apr 18, 2006 | 09:27 PM
kl92gt's Avatar
kl92gt
on mine the ac tube thats by the header the rubber cover that goes around it fell off and the tube was sitting on the header making hot so i moved the pipe and now its fine
Old Apr 18, 2006 | 09:50 PM
z24stang's Avatar
z24stang
ORIGINAL: FiveLiterRiceEater
i beleive the oils are also different
vargas
Jun 17, 2017 12:17 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
69Volunteer
Sep 30, 2015 10:39 AM
