under drive pullies
RE: under drive pullies
actually the smaller the pulley the faster it will turn. the water pump pulley should be smaller than the crank pulley cause if the crank pulley is bigger the car would have an overheating prob.
ok there we go. i thought you meant that the water pump pulley should be smaller than the crank. sorry i am just a F#&k up tonight and am all confused. probably cause 4:20 is in two days!!!!! just kidding [:'(]
i think you got like half way ripped! could you tell us the sizes again, i read them but remember in order to underdrive your accesories then you need to well...underdrive them meaning that they should be smaller for faster belt travel freeing up hp. the bigger the pulley the longer it takes to turn and the harder your engine works
dalefrancis88
09-11-2015 07:15 AM
