rear end rebuild
RE: rear end rebuild
iv'e been busy as hell tim.
atleast somebody noticed..........
i'm trying to con the better half to go to the track tomorrow.
ORIGINAL: Tims 88GT
^^agree but i still would by new gears u never know if they got really hot or something. Whats up art i have not seen u around a whole lot?
but, if you know people like i do...i had mine done for 350.....c-clips/33's/eaton,with kevlar clutch's/3 1/2 in. studs..the whole shabang!..there name is SLINGBLADE.
ORIGINAL: BlackSVTsnake302
400-1000 dallors to install gears and replace the bearings and seals????? g's... *rethinks gears*
my auto teacher is doing mine... hes not your typical auto teacher tho. help my buddy build a 10 second 351W notchback. i just dont wanna spend alot of money. im leaning towards used. i emailed the guy selling the ones on ebay, he says he didnt even put 10 miles on em.
just gears is $100...
so 350 is with the hook up??[:@] holy shat a gear install alone is ganan run me like 500? plus 200 in gears and seals and stuff, I dont think im ganna do gears then....
I bought my 3.73 and rebuild kit off of ebay for a total of maybe 200 give or take a few dollars. Its been a while since i bought them. I would go with ford racing. Richmond has a history of whinning noises.
If you got a lift you can do it while its in the car. Anytime you get used gears, your taking a chance of getting gear whine. I did my gears myself. Wasnt to much trouble, i did mine also at the local shop class. The teacher wasnt there though. I just got a book on how to do it and went at it. Have never had any trouble with it either.
ok which rebuild kit should i get?
#1 pinion and carrier shims
crush sleeve
pinion seal
pinion nut
ring gear bolts
cover gasket
#2 pinion and carrier shims
crush sleeve
pinion seal
pinion nut
ring gear bolts
cover gasket
pinion gear
carrier bearings
or #3 pinion and carrier shims
crush sleeve
pinion seal
pinion nut
ring gear bolts
cover gasket
pinion gear
carrier bearings
axle shaft bearings
axle shaft seals
i need the one with "posi clutches" or whatever will fix my one wheel burnout problem.
crush sleeve
pinion seal
pinion nut
ring gear bolts
cover gasket
crush sleeve
pinion seal
pinion nut
ring gear bolts
cover gasket
pinion gear
carrier bearings
crush sleeve
pinion seal
pinion nut
ring gear bolts
cover gasket
pinion gear
carrier bearings
axle shaft bearings
axle shaft seals
