Fuel Pump Issue
Old 04-25-2006, 04:05 PM
5.0 MPG
5.0 MPG's Avatar
Default Fuel Pump Issue
Well I just had the fuel pump replaced about 4 months ago. This morning it filled her up and she wouldnt turn over. I cant hear the pump spinning either. I checked the relay and I can hear it clicking when I turn the key and the inertia switch is not engaged. Any ideas what it could be?
5.0 MPG is offline
Old 04-25-2006, 04:28 PM
5.0 MPG
5.0 MPG's Avatar
Default RE: Fuel Pump Issue
bump
5.0 MPG is offline
Old 04-25-2006, 04:37 PM
5.0 MPG
5.0 MPG's Avatar
is there a fuse? Where?
5.0 MPG is offline
Old 04-25-2006, 04:49 PM
Tims 88GT
Tims 88GT's Avatar
could be the relay went bad
Tims 88GT is offline
Old 04-25-2006, 04:51 PM
kevstang87
kevstang87's Avatar
Defective pump maybe
kevstang87 is offline
Old 04-25-2006, 04:56 PM
5.0 MPG
5.0 MPG's Avatar
I pulled the relay out from under the seat and turned the key over, I can hear it clicking so I dont think its the relay. Is there a fuse under the hood for the pump?
I hope its not the pump itself I just filled it up to the brim.
5.0 MPG is offline
Old 04-25-2006, 05:10 PM
kevstang87
kevstang87's Avatar
On my 87 I put a new fuel pump in...I did not test it before I put the thing back up .
I turned the key...I did not hear the pump kick on and nothing...Come to find out it was a defective pump. What an idiot I was for not testing it 1st... I guess you live and learn
Old 04-25-2006, 06:59 PM
5.0 MPG
5.0 MPG's Avatar
bump
5.0 MPG is offline
Old 04-25-2006, 07:40 PM
Joel5.0
Joel5.0's Avatar
Use this '91 wiring diagram (Courtesy of TMoss and Veryuseful.com), I know you hear the relay clicking, but you need to make sure the relay contact points are not damaged, not allowing voltage to get through the relay to the pump.
Check the Dk Grn/Yel wire pin at the FP relay for voltage, with a test light, when you hear the relay activate....if you don't get voltage out, the relay needs to be replaced......if you get voltage, do the same test at the inertia switch....if you get voltage at both ends of the cutoff switch....there's a good possibility the pump is bad....unless there is a contact problem at the connector on the tank. My 2ยข.
Joel5.0 is offline
Old 04-25-2006, 10:21 PM
5.0 MPG
5.0 MPG's Avatar
good stuff thanks. I decided to go ahead and drop the tank and check the pump direct off the battery. I got it down but which ring loosens the pump on top of the tank (theres 2) and is it loosened counterclockwise?
5.0 MPG is offline
Quick Reply: Fuel Pump Issue
