stroker kit
Old Apr 26, 2006 | 10:53 PM
8URWS6's Avatar
8URWS6
Default stroker kit
Guys which is better a 347 or a 331?
I know a 331 would "bolt right in" and a 347 will need the block notched for the rods to clear.
Is it worth the effort?
Old Apr 26, 2006 | 10:54 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: stroker kit
a 408 is much better than either
Old Apr 27, 2006 | 08:02 PM
95stang_low12s_motor's Avatar
i went with the 331 - the loss in cubes is made up for with strength and efficiency. Rings wear quickly with the 347 and the 16 extra cubes is not worth it. My two cents.
Are you using the stock block? Or did you find a Mexican Block? I couldnt find a Mexican 302 so i went with a sportsman block from ford
Old Apr 27, 2006 | 08:09 PM
ikeybmg's Avatar
ikeybmg
i like my 347. more cubes the better. the new kits are just as efficient as the 331.
Old Apr 27, 2006 | 08:33 PM
r.barn's Avatar
r.barn
347 will give you most power
331 keeps orginal 302 valve geometry or something like that
so its easier long term on all the moving parts.
Old Apr 27, 2006 | 08:36 PM
randy78045's Avatar
randy78045
I like my 408...
Old Apr 27, 2006 | 08:40 PM
86HOGT's Avatar
86HOGT
Explain to me how the stroke of the crank and different pistons make the valvetrain geomtery different? lol....
I'm going to be rockin with the 347 here in a month.
ORIGINAL: r.barn
Old Apr 27, 2006 | 08:50 PM
5.0stanger's Avatar
5.0stanger
I always hear more cubes = more power, but less weight = faster revs. I think it is a trade off some times. Built 302 will out rev a 347, it will have less power, but get into it quicker.
Old Apr 27, 2006 | 11:26 PM
8URWS6's Avatar
8URWS6
I am using the stock block. They said that the stock block will go up to 500 Hp. Is that true?
ORIGINAL: 95stang_low12s_motor
Old Apr 27, 2006 | 11:46 PM
GaryBisiniere's Avatar
GaryBisiniere
if your going to use the stock block i would def have it machined
