Help!!!! PIC now
Help!!!! PIC now
I ran into a problem. I started working on putting the bushings i got in the rear of the car. i took the passingers side upper control arm off and was looking at everything. and the metal sleave that goes into the axel where the bushing goes in is half warn off. this is why the car does not pull stright. ill get a pic in a second. my question is where can i get this sleave????
RE: Help!!!!
You can get poly bushings that go into those metal sleeves pressed into the rear axel housing from http://www.brothersperformance.com/c...roducts_id/551, www.jegs.com, or www.summitracing.com .
Basically, you remove the worn out rubber by drilling around the bushing until you can pry the "carcass" rubber out of the shell. If your's are as bad as mine were? I only pried them out using 2 screwdrivers & never used a drill......
RE: Help!!!! PIC now
As u can see i have an issue[:@] it never ends
[IMG]local://upfiles/11994/936F74B7642942669CF838733AA5296E.jpg[/IMG]
[IMG]local://upfiles/11994/9E94C2AFDF4748068267FF91DCF8A337.jpg[/IMG]
