Twisted wedge head pushrods?
Hi, I emailed Trick Flow couple days ago with the question, will stock pushrods from a '95 GT work with their heads. They haven't gotten back to me yet. I have an E303 cam, and their site says needs other pushrods but to see directions. I am buying used heads and hence no directions...
Can anybody help me out here... the guy I'm buying the heads off of says he'll send his pushrods from his TF cam, but I'm not sure they'll work either. Anybody know the correct size I will need with 1.6 rollers...
Thanks
Thanks
RE: Twisted wedge head pushrods?
Im pretty sure i read somewhere that the heads needed .50" longer than stock pushrods. At any rate weather or not im correct on the above, you should get some aftermarket hardened pushrods and guide plates to go with the heads. ALSO, don't use the stock Stamped style rocker arms with em. They say that the stockers will wear the seats out, so use some good true roller rocker arms with them as well just to be safe.
One more thing, before you slap the other guys pushrods in your engine, buy a pushrod length checker and make sure of the size you need. They're not too complicated to use, and they're relativly cheap as opposed to bending the pushrod, or a valve or something silly. Check summit, or jegs for the pushrod checker.
ORIGINAL: Tims 88GT
^^im going to use trick flow rockers with mine. i thought they used a longer push rod. that sucks i have hardend stock legnth.
you do need longer push rods for the Twisted Wedge heads
you need 6.7" rods.
http://store.summitracing.com/partde...5&autoview=sku
these are the same rods they sell in their complete
kit with 1.6 rocker arms
you need 6.7" rods.
ORIGINAL: Tims 88GT
U can use ford rockers to.
