timing chain
RE: timing chain
you dont have to replace it very often. i think every 100k.
to get to it you'll have to remove the water pump and timing cover. its basically 2 gears. a small one on the crankshaft, and a large one on the cam. the small one slides on and the large one is bolted to the cam with 3 bolts. pretty simple to replace, you just have to align two marks when you put it on and have the engine at top dead center.
RE: timing chain
i didnt know these had knock sensors. but you can put a resistor in the knock sensor circuit so the voltage will never go out of the sensor range.
basically a knock sensor is a piezo crystal or some crap. when you hit it hard enough, or it gets a big enough vibration, it creates a voltage. if you wire a resistor into the circuit, the voltage wont pass the resistor, therefor, no check engine light, and no trouble code, and no problem
