5 speed swap (extra wire connection)
ok i'm in the middle of my swap and i was able to get the pedals in, speedo/clutch cable moved and all the wires connected (i hope there the right ones) but i have a question about one wire connection. the only wire connection that i have left if the one that does in to the cable assembly that is hooked in to the ignitions to the auto shifter. its a small connection that had 3 wires coming out of it. i take it that there is a sensor inside this thing that tells the ignition when the car is in park or not. now what the heck do i do with this connection? do i have to jumper it to complete the circuit, or just leave it unpluged?
RE: 5 speed swap (extra wire connection)
Hmm, I have not heard of an issue with that. I suspect it simply needs to be jumpered or perhaps it can be left alone. You'll need a service manual to tell you what it is and how it works. The diagnosis portion for that sensor aught to tell you how to bypass it.
is it for your reverse lights??
i just finished the swap and there is one harness that i left alone and it works just fine.....its the harness that is coming out of the top of the tranny.....if that helps ....
i haven't done anyone thing with the trans harness yet. but the plug i'm talking about plugs into the cable assembly that is attached to the ignition and the cable goes to the aod shifter. like i said im not sure what the heck it does and i dont know what to do with the damn thing???
musnicki
09-23-2015 07:11 AM
