Oil Consumption
Oil Consumption
Hello;
My 89 5sp seems to have a thirst for oil. I've had to add 2 quarts in 3000 miles. No noticable leaks. It is coming out the pipes. I notice a little blue smoke under hard acceleration but that's it. How bad is it? I'm thinking piston rings are the culprit, any other suggestions? Thanks in advance.
RE: Oil Consumption
Thanks. It does not smoke when I let off the throttle. Only when you get on it. This is a 75,000 mile engine that runs very strong. I want H/C/I and was hoping to not have to rebuild the bottom end. How can I narrow down exactly where I'm losing oil? Thanks again for your replies.
RE: Oil Consumption
how many miles on the car? my car uses about 1-2 between changes... but i have NO SMOKE no leaks no nothin...
it is most likely the valve seals. Do a compression test, if that gives good numers it's probably in ur top end that's the problem
RE: Oil Consumption
Compression test is good idea. Any leakage out of rear main seal? That wouldn't have anything to do with blue smoke at hard acceleration though. I have an 86 and it seeps a bit from there from time to time. Piston rings or bearings is a distinct possibility, in which a rebuild is a good idea, if budget permits. I had a 90 convert., which had the same issue you're describing.
RE: Oil Consumption
Thanks for your suggestions. I will perform a compression test and see what is learned. I have no visible leaks from the engine anywhere. Hopefully, it is indeed the valve seals since that will be solved with new heads. The car, by the way, is a clean, untouched 75,000 mile original car (verified by carfax and clean title). The condition of the car is like new. I thought my months of searching for the perfect low mileage 5.0 would have avoided this.
