dash set up
dash set up
i just bought another mustang its a notch back with a 86 engine all worked up trick flow cam and heads, holly carb, tremmic tranny king cobra clutch, the things a wounder runs high 11's on motor i know the kid i bought it from .... the only problem is he took the dash apart for the heater core and does not know hwo to put it back .... so does anyone know of or have the correct diagram for me to reconnect the wires and the dash back together ???? thanks ... matt
RE: dash set up
Is the whole dash torn out..? What are you're plans for the car?
If you're wanting to make this into a nice fast beauty i'd say buy some sheet metal and make you're own dash. It's not expensive, you'll throwout a lot of weight, plus it will give you you're own custom look.
RE: dash set up
You may need to go to a junkyard and take some pictures. It helped me a lot. But for the most part they will only fit in certain connectors. If you study them a little you will notice missing terminals inside the connectors and this is an easy indication of what to look for in the corresponding plug, plus they match up and so forth. Just start connecting them and you'll find out that your probaly only dealing with a couple that can connect in multiple areas.
breaking
10-02-2015 01:27 PM
