Better cam?
Old Mar 27, 2004 | 11:45 PM
90lxtyson's Avatar
90lxtyson
Default Better cam?
I am building a mild motor. TFStreet, gt40p heads 70mm TB 76mm C&l mass air 24# inj. any ideas on a cam. Was going to go with the E303 anything better with good street idle and driveability
Old Mar 28, 2004 | 12:33 AM
Obsol3te's Avatar
Obsol3te
Default RE: Better cam?
im usin the B303 cam
and its very streetable
LOVE its idle too
Old Mar 28, 2004 | 01:01 AM
Milky's Avatar
Milky
I agree, b303 would work great. 1.7 rockers will add a lot of lift to it. Ive got a b303 to sell you if youd like, only 2 or 3k miles on it...
Old Mar 28, 2004 | 01:20 AM
90lxtyson's Avatar
90lxtyson
I have 1.6 rockers already, how are the crane cams? I have heard good things about the 2020?
Old Mar 28, 2004 | 01:22 AM
Milky's Avatar
Milky
Crane is fine... honestly to me-a cam is a cam as long as its machined correctly... the 1.7 add .030 to your lift.
Old Mar 28, 2004 | 12:11 PM
90lxtyson's Avatar
90lxtyson
I am looking for a cam that will work with my combo. with out the idle prob. any ideas? split duration?
Old Mar 28, 2004 | 12:18 PM
vfast's Avatar
vfast
I ♥ Acer
cam is not a cam....first you ned to sit back and think what you want from the car....I'd steer away from the ABC CAMS you need more lift on the exhaust side and those cams don't haveany only a lil more duration....if you can pm me with all your mods and any future mods I can steer you to a few good cams that make good power and vacuum...just let me know
Old Mar 28, 2004 | 12:23 PM
90lxtyson's Avatar
90lxtyson
Thanks vfast, I am doing a fresh bottom end with main support, gt40p heads with better springs, Trick Flow street intake 76mm mass air w/24lb inj. t-5 and 3.27 gears any thing else you need. I drive the car everyday to work so it can't be crazy.
Old Mar 28, 2004 | 01:18 PM
roundman's Avatar
roundman
you can always call the cam companies and get their tech support people to help you select which cam will work best for what you have and what you want it to do, now and in the future. since they do this for a living, they should know better than anyone what works and what doesn't! I like Comp Cams over Crane, but that's just personal preference.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
