Changing right motor mount--easy or hard?
RE: Changing right motor mount--easy or hard?
ORIGINAL: 81ponycar
i would do it at home, do you have a cherry picker to lift the motor a little bit?
Where are my manners! Thanks for the reply.
The easiest way is to put the car up on jackstands, then lift engine with jack. The job is very easy. It will probably take as long to put it on jackstands as it takes to swap the mount.
ORIGINAL: TAPOUT
yes, from underneath. Put a 2x4 or something between the oil pan and your jack to help disperse the weight a little. I would also replace both of them while your doing it....your post sounded like you were just doing one
ORIGINAL: gspfunk
