coil replacement
Old May 3, 2006 | 08:36 PM
92fox50's Avatar
92fox50
Default coil replacement
What do you recommend when replacing the stock coil. I have an MSD ingition system w/boost retard for the s trim. the coil was never replaced and the car is dying at idle and while i'm cruising at times due to overheating. I think it's the coil since it's stock, and my distributor is ford with the motorsport wires........please let me know and when changing it, is it as easy as removing the pos/neg wires and just swapping it out, do i need to disconnect the battery when doing this?
Old May 3, 2006 | 09:02 PM
meiguoren33's Avatar
meiguoren33
Default RE: coil replacement
Use the MSD replacement TFI coil. No you don't have to remove the batt cables. Just plug and unplug the connectors when you swap coils, it's that easy.
Granatelli Sales
Mar 25, 2016 08:01 PM
5.0muscle
Jan 11, 2016 01:17 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
StalkerGT
Sep 25, 2015 02:41 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
