Power Window Problem
Old May 4, 2006 | 12:47 PM
wildcobrar's Avatar
wildcobrar
Default RE: Power Window Problem
I would also check the wire harness right at the driver door opening. I had a couple wires break right at the driver's door harness under the top door hinge. It shut everything down on me. (Both windows because the driver side is the master control)
Old May 4, 2006 | 12:52 PM
HACKGT350's Avatar
HACKGT350
or you can do what i did when my passenger window got stuck i put a couple towels in the car so when it rained the passenger had the towels over them to keep them and the seat drive hahaha
Old May 4, 2006 | 01:36 PM
BayAreaStang's Avatar
BayAreaStang
yeah earlier this morning, I started pulling out fuses..I found aburnt 1..replaced it...and it worked..so it was the fuse afterall..I thought it would b something a bit more complicated..hahaha..well thanks all for the help
Old May 4, 2006 | 01:39 PM
5.0 MPG's Avatar
5.0 MPG
That sounds like a fuse or your driver side switch. My passenger side window did the same thing and I had to replace the driver side switch. Also it may be the plastic gears inside the motors. They crumble and can jam the motor. You can buy the replacement kit on ebay for a couple bucks. While your at it you might as well buy the plastic window guides and replace them as well........
Old May 4, 2006 | 02:30 PM
r.barn's Avatar
r.barn
mine quit working and it ended up being a coroded relay up behind
the dash, had to hire mechanic to find it, after i tried new switches and fuses.
$300 to replace a $30 part
Old Sep 4, 2006 | 07:59 PM
dwilliams's Avatar
dwilliams
I didn't see what year model this mustang was that had the problem - I have a 2002 Mustang, 3 times over a period of 6 months, the driver side window wouldn't go back up, but the next morning, it went back up. Then a few weeks ago, it wouldn't go back up and the next morning, the next morning and the next morning it wouldn't go back up.
I took it to a shop - they replaced the motor ($166 for the job). Two days later, the same problem occurred again - window would not go back up. I was out of town, so my wife took it back. They did something to make it start working again but don't know what. I got back in town - then it happened again.
This is looking like one of those things where I could spend hundreds of dollars and still not get it fixed. If there is something I can do myself when it happens, I'd like to know. The Ford place said if they work on it, they will replace the motor (again), replace the wiring harness AND the window itself and it will cost over $700. I don't want to go that route if I can do something myself.
I saw posts about popping the door panels and hitting some gear. I've tried to pop them off, but they don't seem to want to come off. I'm afraid to force them too much for fear of breaking something. I can get the window/door lock/mirror control off easily - I see a slot for a screwdriver and it just pops off. But I can't get to anything from there. I don't see screwdriver slots for the door panels themselves.
Does anyone know on a 2002 Mustang how to safely get the door panels off? Does the "smack the gear" thing work for a 2002? Any suggestions?
Thanks,
Doug
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
