Power Window Problem
Old May 3, 2006 | 09:42 PM
BayAreaStang's Avatar
BayAreaStang
Default Power Window Problem
Hey, i just bought a mustang, and the power windows were working fine, i put it down about fifteen minutes ago because it was hot, but by the time i got to the parking lot, i couldn't put them back up, both sides are messed up, i was thinking i had a window lock but there is none, you guys have any suggestions? i was thinking the fuse but i dont have a manual so i dont kno what fuse it could be.
Old May 3, 2006 | 09:44 PM
HACKGT350's Avatar
HACKGT350
Default RE: Power Window Problem
very common pop the panal off and hit the sprocket wheel with a hammer or the motor they should go back up happens to me at least once a month haha too lazy to get new motors. just dont put them down all the way next time
Old May 3, 2006 | 09:45 PM
BayAreaStang
oh ok im going to go try that right now.
Old May 3, 2006 | 09:49 PM
HACKGT350's Avatar
HACKGT350
knock on them hard just not too hard you dont want to break anything but it should work
Old May 3, 2006 | 09:53 PM
BayAreaStang
the panel u mean screw on top of the power window lock righT? sorry im newb...i been hittin them it didnt work hahaha or maybe im doing it wrong.
Old May 3, 2006 | 10:16 PM
HACKGT350's Avatar
HACKGT350
no take the whole door panel off. you gotta unbolt the arm rest and take the panel off so you can see the inside of the door
Old May 3, 2006 | 10:19 PM
ZachW04Stang's Avatar
ZachW04Stang
When it happens to me I take a flat head screw driver and stick the flat part on one of the teeth on the gear driven by the motor. You hammer down on it pretty damn hard. Should go back up after that.
Old May 3, 2006 | 10:20 PM
HACKGT350's Avatar
HACKGT350
i just smack that wheel pretty hard with a hammer and it goes back up does it every time and i have done it quite a bit
Old May 4, 2006 | 05:26 AM
BayAreaStang
hmm, sorry for late replies but i went to a concert, anyways..i took off taht whole panel and i seen 2 little pieces but i didnt see any wheels, i whacked both of those hard and it didnt seem to work, do you think it could be the fusE? if so where is the fuse for the windows because i dont have the manuel.....thanks for all help though guys
Old May 4, 2006 | 12:40 PM
HACKGT350's Avatar
HACKGT350
just start pulling fuses till you find the blown one i dont now if your fuse box is the same as mine since i have an 84. but the wheel is at the front of the door up by the hinges. you should be able to see it its huge it looks like the big sprocket off a bike only a lot thicker
