valve float.
#23
RE: valve float.
ORIGINAL: philthy89fifty
honestly i don't know when my rpm's are up that high i usually went about getting them there in an agressive way. why do you ask?
#24
RE: valve float.
pro i know what you are talking about....prior to current set up..i had this happen with my afr 's...
3rd at 5500 accelerating quickly then silence thenas i pushed clutch in slowing down let off caught it self
2nd time this happened my rpms stayed 5700 never went up..
#25
RE: valve float.
ORIGINAL: grabbem88
#26
RE: valve float.
that's what summit/afr/rich anderson/jay allen told me....i asked alot of people...my fuel psi never dropped....
had my other gauge hooked up so i could see...that was the first thing i thought was lack of fuel.
excessive load hurts weaker springs....also my timing chain was totally stretched.
#27
RE: valve float.
ORIGINAL: grabbem88
#28
RE: valve float.
Yes, its possible as long as you have compressed air.
You will need the spark plug adapter... usually no more than 5$, although Lisle makes one for 14 and 18mm plug hose with 0 rings and a 1ft rubber hose for about 10$. You can get these at a pepboys, advance, Strauss etc. Anyway, Pressurize the cylinder with the compressed air at 140-150 PSI. Make sure you have an adequate compressor (a small nail gun pancake type wont work) because any drop inpressure means the valve can fall into the cylinder. Youll need an overhead valve spring compressor... not one that looks like a C clamp, the one that looks almost like a 2 jaw puller if u will. The air will hold the valves in place, compress the springs, and replace. Make sure you DO NOT LOOSE THE KEEPERS!!!!!!!!!!!!! They are a bitch to find
Jim
Jim
#29
RE: valve float.
Tim, you're floating at 5400!? Wow. I've had my 145k mi engine up past 6000 and then the fuel gets cut out...***sigh***...can't wait to rev my 347 at 7000...maybe if AFR would get off their *** I could get it in....
