Should I...
Should I...
I'm trying to decide whether or not to try to lower my oil consumption by using some product to clean my piston rings and ring lands. Once I did a Marvel Mystery Oil piston-soak on an old racebike that had been ridden so gently that everything was carboned up, and it worked. The oil consumption nearly disappeared. Then, another time, I did the same thing on another bike (that I think was abused), and it made the oil consumption worse. My questions are:
1. Do these engines have a propensity for carboned-up rings and lands?
2. Has anyone been successful using products like Seafoam and MMO to lower oil consumption?
Thanks again.
Thanks again.
RE: Should I...
Actually, there is a leak from somewhere down low; it just doesn't seem like that could account for such oil loss. It's either my rear main seal, or my rear oil drain bolt leaking. Haven't been under there in a while. At any rate, it just leaves a drip or two in the garage every night. The thing is, I think it is burning most of it for two reasons: 1. There is soot in my tailpipes, and 2. My thermactor crossover pipe was clogged with soot/carbon. What do you think?
RE: Should I...
ORIGINAL: PRO50SC
How many miles on the motor? Does it smoke from the t-pipes?
RE: Should I...
ORIGINAL: grabbem88
no leaks?....chk pcv?....
RE: Should I...
ORIGINAL: grabbem88
might be a little rich,and washes some oil away with the burn.....it might drip more when running?.
