Transmission pan with temp sensor in it?
#21
RE: Transmission pan with temp sensor in it?
Check and see if your current sender will screw into the drain plug hole.It should screw out of the bung the guy welded into your existing pan. If the sender wont fit the pan take both to the hardware store and find some brass fittings that will make the two work.
If the sender wont come out you can buy senders from the gauge manufacture.Autometers come with a couple different fittings and one sender.
Edit: That B&M pan is sweet.[sm=drooldude.gif]
