dead battery problems
Old Mar 31, 2004 | 02:46 PM
roundman's Avatar
roundman
Default RE: dead battery problems
blame it on the wife, huh? whatsamatteru, your eyes don't work at night? lol
Old Mar 31, 2004 | 05:57 PM
WNDSOR's Avatar
WNDSOR
dont put water in the battery, that does nothing. its probably your alt not charging, pretty sure its not the ecm
Old Mar 31, 2004 | 06:28 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Forget all that up top.If you want to see if its a battery or a alternator start the car up and disconnect the negative terminal on the battery.If the car stays running with the battery disconnected its the battery.But if the car immediately dies its your alternator and or a voltage regulator.
Old Mar 31, 2004 | 06:29 PM
50fiend's Avatar
50fiend
You're kidding right? If you have a battery that is supposed to be filled with water and it's not it will not hold a charge.
TheGmKiller331
I ♥ Acer
And for the record much like the radiator the battery needs distilled water in it not tap water.
Old Mar 31, 2004 | 06:40 PM
BoostedStallion's Avatar
BoostedStallion
My dad had the same problem on his 1989 mustang gt. He solved it by using a better moniter or something, (ill have to ask my dad what it was called when he gets back) You attach it to your battery and it charges your battery when it gets low, you just attach it to a 3 plug extension cord. Its 30 bucks at autozone...
Old Mar 31, 2004 | 06:50 PM
TheGmKiller331
I ♥ Acer
ORIGINAL: WNDSOR
Yes you do have to add water to them if they get low but only use distilled water like in the radiator.
Nurdyguy
Jan 20, 2025 04:38 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
Art161
Sep 9, 2015 10:33 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
