where to put gauges?? need a some opions
RE: where to put gauges?? need a some opions
thats how you do most of the f/p guages. i just think it looks tacky leavin the whole guage under the hood. especially the big ones.
by the way, your all's tachs are too damn big!
Yea i like that set up to.
ORIGINAL: randy78045
Actually you can put them in the vents or another option is a pod/plate that surrounds your radio and has space for three small gauges... got on sitting right here... just havent installed it yet...
http://i67.photobucket.com/albums/h2...irepics067.jpg
i got the autometer schrader valve adapter for $8.00 and then got a brass 45degree angle with a small extention and a summit liquid filled fuel gauge.. cheap and easy.. works great and i can see it while adjusting the fuel pressure.
no way i just wanted something simple small and something that does the trick. the only reason i needed the 45 degree angle and the extention was i have edelbrock tall valve covers, and i needed a 1" spacer between the upper and lower intake so it would hit with out the extention..
