Cam help
Old May 11, 2006 | 12:22 AM
fordaorm's Avatar
fordaorm
Default Cam help
Ok im puttin in a stock 99 explorer 302 in my stang just switching it all the electronics over to the current setup of my 93 GT. 99 Explorer has GT40 intake and Pheads. Im puttin in double springs to keep the valves from floating. Im Runnin 150 shot NOS, 3.73 gears, BBK CAI, And 24# Inj. This is a street/strip car. Need help on which cam to go with without haveing to cut the pistons.. Any ideas?
Oops i forgot to add i have and AOD with 1800 stall conv.
Old May 11, 2006 | 12:41 AM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
Default RE: Cam help
How do you know what springs to put in it if you don't know what cam your going to use?
Old May 11, 2006 | 12:59 AM
fordaorm's Avatar
fordaorm
changin the springs on the P heads is a given reguardless of cam stock Ford springs Float at High RPMs....
Old May 11, 2006 | 01:01 AM
Grimace5.0's Avatar
Grimace5.0
I ♥ Acer
ORIGINAL: fordaorm
How high you going to turn it?
Old May 11, 2006 | 11:05 AM
fordaorm's Avatar
fordaorm
1800 TO THE 5500 RANGE
Old May 11, 2006 | 11:18 AM
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: fordaorm
How could one have the springs then want a cam recommendation, you dont know recommended installed height, coil bind and other factors. Your doing it backwards and will possibly bite you in the *** real quick
Old May 11, 2006 | 12:08 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
Actually going with a better spring is fine, I do it all the time. He is right about the stockers floating at RPM's much above 5000 rpm. He won't really hurt anything. How do you guys think we spun a stock cammed 302 to nearly 7000 rpm and made 520+ rwhp? (it had a blower as well)
Old May 11, 2006 | 12:29 PM
myshifter's Avatar
myshifter
I ♥ Acer
ORIGINAL: JD1969
Its not an issue of going to a better spring, its about buying springs first then matching the cam, when that is totally backwards
Old May 11, 2006 | 12:43 PM
ikeybmg's Avatar
ikeybmg
i bought my assembled victor jr heads. .650 lift rated springs. then a cam. id get an E cam or a TF st.1. buying springs first is nothing major if you know youre not gonna be liftin .600+ or something, which i doubt hell be doing since he dont wanna cut the pistons.
Old May 11, 2006 | 05:16 PM
JD1969's Avatar
JD1969
ORIGINAL: myshifter.com
ORIGINAL: JD1969
True that is a backwards way of doing it, but it's not really going to hurt anything. If it were my car I would just leave the stock cam in it unless he has aftermarket heads.
