Timing on a 302
#41
RE: Timing on a 302
ORIGINAL: ltownracing
Yeah Leonardtown Maryland
93 is 3.10 cam 2 is like 4.10
#43
RE: Timing on a 302
A harmonic balancer can be bolted up ONLY 1 way, its keyed. There is a ring of rubber between the out side ring and the part that bolts to the crank. When this rubber gets too hot or someone cranks on it it can turn on the rubber and not go back to the original position. I run my car @ 13 degrees, my old '79 flat tappet motor I ran @ 5 ATDC. LOL! For some reason it would run right at the factory setting, thinkin maybe my cam was off a tooth.
-P.
-P.
#44
RE: Timing on a 302
Most of the times the rubber isolator which is between both rings dampens the rotational vibrations and over time dry rots and looses its tension and allows the outer ring to turn, obviously the inner ring wont turn since its bolted to the crank and held with a key
#45
RE: Timing on a 302
My balancer spun.....replaced it with a FRPP Balancer.....if this is the same case as yours....a timing light is useless....not only that, but if it serpates completely...say goodbye to your rad, timing cover...anything else it hits....those balancers are not LIGHT!!...get it checked out before it cost more money!!!!!
#46
RE: Timing on a 302
Yeah i know where that is. I race alot at maryland international raceway. There alot of people that come at of waldorf and some from crofton to race. Winchester Va would be a little bit of a hike though.. haha
mungodrums
10-07-2015 04:01 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
