INJECTIR SIZE HELP!!
May 13, 2006 | 11:13 PM
I have a 10:1, 331, afr 185cc, heads, and edelbrock rpmII intake, i dont have a clue about what size injectors i will need help please
May 13, 2006 | 11:18 PM
RE: INJECTIR SIZE HELP!!
24lbs injectors, 190 lph pump, Mass Air meter changed over to match injectors.
wouldnt be a bad idea to run bigger 7/16 fuel supply lines from the tank too.
May 13, 2006 | 11:25 PM
30lb injectors, 190lph fue pump, 76+mm maf for injectors.
May 13, 2006 | 11:30 PM
would a 255lph pump hurt any thing. just so i have a little in reserve.
May 13, 2006 | 11:31 PM
na
May 13, 2006 | 11:32 PM
just letting u know when u need a 255lph pump to supply a motor, that means u need to re-do the whole fuel system
May 13, 2006 | 11:36 PM
unless you plan on a power adder #24 will be all you'll need imo
May 13, 2006 | 11:37 PM
im with tim on the 30# injectors
May 14, 2006 | 12:01 AM
^^thanks i bet 100 bones he needs 30's
May 14, 2006 | 09:51 AM
Thanks for the help i was getting ready to buy #36 injectors i think i will back off on the size a little. THANKS AGAIN
