CCRM
RE: CCRM
Constant Control Relay moduale....on my 95 it is located right by the Overflow bottle, in 95, the CCRM controled the fuel pump and other things aswell, i would check it out if i were you...an older stang might be different
RE: CCRM
Its not staying running...I will crank on the key...and you know when your car is going to start...you get that one turn of the engine and you let the key go, well when i let my key go it wont stay running( i get that one ROMP!!! and it dies) But when I hold the key over and let the starter keep turning the motor I can give it gas( so I know its getting fuel).... it has a new fuel pump, new fuel pump relay, new starter relay(solenoid), new ignition, new ignition switch on the column, new wires new plugs...
RE: CCRM
Maybe the gap is wrong...I have the plugs gapped at .054...is that wrong...and the car would be that sensitive as the throtle body being air tight, and how do i check the air pressure...like the earlier post before Im new to mustang fever...I am sadly to say that I used to be a chevy guy(97 Camaro) they just dont have what it takes when it comes to for mustangs....
