Auto Notch 1/4 mile et?
#21
RE: Auto Notch 1/4 mile et?
So when you race, how do you shift your automatic?
With my auto and stock shifter, I can only manually shift from 1st to 2nd, but it automatically shift's from 2nd to 3rd so it will shift at a lower rpm than what I want it to.
Any suggestions?
Any suggestions?
#23
ORIGINAL: PRO50SC
Faster than 16.0 slower than 14.5
i ran 14.47 in my '90 GT aod 100% bone stock
it had 3.27 gears stock and depending what you have will make the difference between 14's and 15's
My '90 lx 'vert aod went 15.10 w/ 3.73's
door tag has "ax code" m=2.73 z= 3.08 e= 3.27
go have fun w/ it....i doubt you'll see 15's , should run ez 14.50's if you drive it hard enough, and maybe take a short belt gates 4060695 will bypass the smog and PS
#24
ORIGINAL: ckyguy68
try the 1-D-1 shuffle.
if you need it to stay together.....better not.
intermediate clutches don't like to stay engaged when they are not supposed to. forcing them to causes buku broken parts.
#25
ORIGINAL: nitrous_bob
yeah, but only if you don't need your trans anymore.
ORIGINAL: ckyguy68
unless u want a reason to get a new tranny
#26
quote:
ORIGINAL: ckyguy68
ORIGINAL: ckyguy68
But there has to be a way to modify this other than a manusl valve body, and B&M Shifter.
Anyone have any suggestions! (besides swap it for a 5 speed...)
Thanks,
Darrin
#27
ORIGINAL: YNotch?
Yea since the tranny has only 5K on a rebuild with a shift kit, I don't think that will work for me,
Thanks,
Darrin
quote:
ORIGINAL: ckyguy68
ORIGINAL: ckyguy68
Thanks,
Darrin
swap it for a 5 speed!
no other option
