Oil pressure.
RE: Oil pressure.
I run 30 weight in my motor and get about 30 psi on a mecanical gauge. The stocker never moves from the middle. I got a mecanical and was shocked at how much the oil pressure changes. It is like 55psi cold and 30 hot and the stocker never moves.
RE: Oil pressure.
my stocker "tries" to move. it will move at turtle speed.
every first morning start its right in the middle and as i drive it goes up a bar which is pretty much normal since the higher rpm's the more pressure
RE: Oil pressure.
I got the napa special and a gauge a piller pod. You just have to plumb in a tee where the oil pressure sender is and run you plastic or copper line up though the dash to the gauge. It was easy and made me feel better to know for sure.
