Engine Rebuild Need Suggestions
RE: Engine Rebuild Need Suggestions
speaking of this while were on it, i found a short block for $700, are these parts good & the compression being 10:1:
pistons: federal mogul or silvolite
rings: hastings
rods: ford oem
rod bearings: federal mogul
main bearings: federal mogul
cam bearings: melling
rear main seal: fel pro
timing set: melling
gaskets: fel pro
oil pump: melling (standard volume)
Each Block Is Heated In A Hi-Tech Cleaning Oven. It Is Then Blasted, Tumbled and Magnafluxed To Insure There Are No Flaws. The Block Is Then Re-Bored And The Cylinder Walls Are Power Honed to 1/1000 Of An Inch To Insure Precision For A Prefect Fit. The Block Is Then Checked Using An Advanced Dial Bore Process To Prove Quality. OEM I-Beam Connecting Rods Are Installed, Camshaft With Original OEM Specifications, New Set Of Pistons and Rings. Crank Is New or Freshly Ground, New Timing Chain & New Timing Gears.
THIS AUCTION IS FOR A PROFESSIONALLY REMANUFACTURED 302/5.0 LITER BLOCK (.030 OVER) DESIGNED FOR HYDRAULIC ROLLER CAMS (1986 TO 1995 MUSTANGS AND OTHER FORD MODELS).
THESE SHORT BLOCKS ARE BUILT FOR 10:1 COMPRESSION WHEN STOCK 58cc HEADS ARE USED.
rings: hastings
rods: ford oem
timing set: melling
gaskets: fel pro
crane and comp both make great rods, lifters, rockers, etc. a long short block to build on IMO, would be bored .030 with a summit 347 stroker kit w/ forged internals, heads of your choice with comp hardened pushrods, lifters, and 1.6 or 1.7 rockers (depending on cam) new double roller timing chain. either E, F, or trickflow st 1 cam. that would be a good base for 350+ n/a hp. if you already have the motor youre looking @ around 3g's in parts give or take.
ORIGINAL: 5.0 MPG
Boy I tell ya! Sometimes I have to hold my fingers back from unleshing on some of these newbs.......
Yea Ive heard about the keith blacks.
How about lifters and rods?
Perfect!
ORIGINAL: ikeybmg
ORIGINAL: 5.0 MPG
the trickflow kit im getting has pushrods, not sure and it has roller lifters. and ill just buy some roller rockers. and for $349 more dollars theyll put forged pistons in that short block. im not going to nos or sc so should i bother with forged pistons or not?
are you planning an n/a setup or power adder? if youre not getting any kind of power adder you could get away with hyperteutic pistons, etc. but i like forged because you have a little more insurance.
no im from ga i wish i lived in texas so i could fine nice rust free mustangs!! but i live on the coast here im about a 5 minute walk to the ocean where they bring in a lot of port stuff new cars etc! the only reason my 65 was in such good shape was cause it was a texas car dso
im just going to get the trickflow kit, some other mods like 24# injectors bigger tb, convert to maf, but no s/c or nos or any power adder like that, so i should just get the hyp. pistons? and what rockers should i go with, the tf kit comes with trickflow cam, heads, double roller timing chain i think? and intake and stuff.
and how good are those pistons and rings and bearings and stuff the federal mogul or w/e.
hypers are alot cheaper and will be ok with that. forged internals are just more reliable with s/c nos etc.
ORIGINAL: Ecstasy
Eventually I want a power adder so forged is the safest bet.
rmodel
Oops I got you confused with r.barn, my bad. You are right though you see a lot of rust buckets just rotting in peoples back yard or in fields in the middle of no where....... Ive bought a couple and restored them with a bud of mine. I already want another.... wheres a field or a barn at?
rmodel
