What # injectors i should get?
Hello,............ just installed a powerdine supercharger. I have now 24lb injectors. Should i go higher? And what else can i use thats bolt on to get the best performance of this supercharger. I also installed edllebrock upper and lower intake and new destributer MSD. thank you.................
RE: What # injectors i should get?
ORIGINAL: 88stangaruu
im curious about this to. How much boost can you run before you need to change from 24's?
Sorry to be a thread ****...not trying to.
how much f/p you have now?....becareful with 24's.....being s/c with 350hp is different than n/a with 350hp....
you have access to a dyno with a wideband??? i'd check it out if you do.
ok lets see
Mac long tube
Mac off road H pipe
Flow Masters
Malory adjustable fuel pressure
Pro M 70 mm mass air sensor
Motorsport 65mm throttle body
Motorsport plugs
edlebrock manifold and lower
MSD Distributer
6lb powerdine supercharger
I need to get a boost guage to check exactly how much boost i have. At idle the car fuel preasure is at 28. I just started workimg on adding more hpower to the stang any help would be nice thanks.
Mac long tube
Mac off road H pipe
Flow Masters
Motorsport plugs
MSD Distributer
