measure for pushrods
Old May 23, 2006 | 04:19 PM
posnick's Avatar
posnick
Default measure for pushrods
how do you measure pushrod length? does it have to be the #1 cylinder on the intake stroke???
Old May 23, 2006 | 04:32 PM
myshifter's Avatar
myshifter
I ♥ Acer
Default RE: measure for pushrods
first you need an adjustable length pushrod which are 10 dollars and you need to setup the full valvetrain preferably with setup springs instead of your regular valve springs, set up both intake and exhaust of one cylinder and you can then begin to measure and play with rod length and check wear pattern on the valve stem by using machinists blue dye.
mtgldr
Feb 3, 2024 09:00 PM
Gene K
Oct 21, 2015 11:37 PM
jrrhd73must
Oct 2, 2015 09:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
LivingInThePast
Sep 16, 2015 12:20 PM
