Everyones opinion please!!!!!!!!!!!
Ok im getting down to where im not sure what else to do to my mustang other than getting a blower which will eventually happen but not right now with school.
Heres a list of my mods now what else should i add in the way of bolt ons or more go fast goodies?
1980 302 block
Elgian 3/4 Race cam
Bored 60 over
Eagle stroker kit
Clevite bearrings
moly rings
forged pistons
heads ported and polished (351)
Edelbrock springs
Manley valves
Fel-Pro gaskets
Edelbrock 1406 carb
Edelbrock 2121 intake gasket matched
3 core modine race radiator
100 amp lincoln alternator upgrade
Serpentine belt conversion (originally V-drive)
Solid motor mounts
Mr.Gasket race scoop with velocity stack
New recurved distributor
C4 transmission
2,000 stall convertor
Transgo shift kit
Aluminum driveshaft
3.73 rear gears
Flex-A-Lite Flex fan
SVO welded and bolted subframe connectors
MOTORSPORT 9mm wires
recurved 85 GT duraspark distributor
HOLLEY SHORTY equal length headers
MOTORSPORT cross member
Mr.Gasket Underdrive pullies on all but alternator
Flowmaster 40 series 3 inch on true duals
What else should i put on?Remember i only want things to make it go faster.And the big thing i want but dont have is a BLOWER but thats got to wait a bit.So what other bolt ons guys/gals?
1980 302 block
Elgian 3/4 Race cam
Bored 60 over
Eagle stroker kit
Clevite bearrings
moly rings
forged pistons
Edelbrock springs
Manley valves
Fel-Pro gaskets
Edelbrock 1406 carb
Solid motor mounts
C4 transmission
Transgo shift kit
Aluminum driveshaft
3.73 rear gears
RE: Everyones opinion please!!!!!!!!!!!
Yeah that would rock but i cant afford the blower.How the hell could i do a twin turbo?
It would be nice but i dont have a clue about turbos other than how they work.
what the hell is a 3/4 race cam?
That makes the assumption that there's a set "race cam" and a set "street cam" and it's 75% of said race cam, right? So if you've got a cam that's just a hair wilder than the "race cam", would that make it a 1 1/8 race cam?
Yes, I'm aware that I may be coming off as a bit of an ***, but I really am interested in the answer to this.
Other than that, can you get enough air through that scoop/velocity stack? I noticed a marked improvement in my truck when I switched from the stock 12x3 enclosed air cleaner to a 14x4" k&n open filter.
Yous ave money for the turbos.
If you don't know a thing about 'em, try reading this book. Damn near the definative.
"Maximum Boost" by Corky Bell.
Steal my e-bay copy and I'll beat ya down with a dictionary.
Nah Turboing isnt my style.Im a big fan of oldschool i like the blown setups much better.
The best part is they still run off my favorite form of fuel delivery CARBS!
Electric fan,(believe me that flexalite is robbing that 331 or more power than you think. and there only rated at like 6000 rpms, i hope that 331 revs higher than that...... 9inch with locker,4 link rear, aluminum heads, bigger cam, Mallory ignition, box, longtubes, Slicks, draglites(but i like the rims you got), and say a 750 carb...... if you wanna spend money go with a demon there grrrrrrreat...
