INTERCHANGABLE??
If I remember correctly the wire harness from the factory should be behind each kick panel (right and left side by your feet and the passenger's feet) and the harness that comes in the doors should run in through the body and plug right in at the areas I mentioned. The only other thing you may need to do is install fuses and circuit breakers in your under dash fuse panel but again I believe you are good to go there too.
polarbear
Sep 3, 2004 11:21 PM
