emblems.
Old May 29, 2006 | 08:36 PM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
Default emblems.
you guys know the ford emblem on the rear passanger side? is that just stuck on with sticky tape or is there like a rivet or something in it?
Old May 29, 2006 | 08:38 PM
OneFine89Mustang's Avatar
OneFine89Mustang
Default RE: emblems.
i believe its just taped on
Old May 29, 2006 | 08:40 PM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
some type of 3M adhesive/sticky-black-crap
if u want to take it off or if its coming off on its own, get some "goo gone" (its real stuff) and get it underneath it. let it sit for a minute and peal it off slowely.
i used a flathead screwdriver with tape on the tip (prevent scratches)
it is pretty time consuming. took me 10-15 minutes just to get the left over sticky crap off the paint
Old May 29, 2006 | 08:43 PM
50mikey's Avatar
50mikey
NO, the FORD emblem on the back is not on there with JUST tape. At least not for the coupes. Mines taped on, but has 2 aligning pins with holes in the deck lid.
Old May 29, 2006 | 08:45 PM
lookinforastang
I ♥ Acer
hmm
when i took my LX badge off it was just some sticky gum type material
Old May 29, 2006 | 08:46 PM
50mikey's Avatar
50mikey
must just be the coupe then. cause I didnt want to put mine back on after i got it painted, but forgot to fill the holes.
Old May 29, 2006 | 09:18 PM
FiveLiterRiceEater
yeah i was thinking there was some type of pins back there. were the pins held on from the back with anything? or did they just slide in the holes?
Old May 29, 2006 | 10:25 PM
5.0 MPG's Avatar
5.0 MPG
they just slide in.
Old May 29, 2006 | 11:34 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the pins just align it take some mig wire and saw the adhesive in to with the wire and then remove the rest of the tape with 3m adhesive remover!
Old May 30, 2006 | 12:20 AM
99mustang0's Avatar
99mustang0
ya there will be 2 little holes if you do that. Its easy to fix though, i took mine off and filled the holes. Looks alot better with nothing there. I have also seen some people with the same badge except it says "steeda" instead of ford. I think that looks cool too.
