emblems.
ya mine have pins.. but im putting new ones on and there chrome ford emblems but they dont have pins ?? dont know why there of a F150.. but they will look wicked on my pony.. so ima use some 3m glue or what ever that is.. i dont wont them to come of any how ya know?
ORIGINAL: 99mustang0
ya, just filled the holes with bondo. make sure the bondo has something to latch onto though. Its really easy and turned out good.
no dont use bondo! it will fall thru the hole!also the back side will have exposed bodyfiller and it will absorb water! grind the area down and mig the wholes and then grind down the welds finish with body filler best way or after grinding down the area tap the area lower than the surrounding area mix up some fiber glass resin and cut out a small patch lay down let dry sand smooth finish with bodyfiller!
mm wow good thinkn bro.. then maybe i will glow 2 screws on to the emblem.. with the best glue i can find and then run the 2 screws that are attached to the emblem though the holes n run nuts though them?? would that work also u think chrome ford emblems would look good? i think it will be differnt witch is what i like
ORIGINAL: rmodel65
addison85
34
Jul 7, 2008 09:34 PM
