Steering squeek
Old May 31, 2006 | 06:16 PM
FastLane034's Avatar
FastLane034
Default Steering squeek
Well whenever I turn right (NOT LEFT) it sounds like a small CREEEEEEAK only when I turn right. I took it into the shop and this idiot told me its nothing to worry about its just plastic touching metal and it might go away. Is there anything I can do to make it stop? Thanks
Old May 31, 2006 | 06:31 PM
detroit50's Avatar
detroit50
Default RE: Steering squeek
my car was doin the same thing. When I put it on the lift I noticed one of the hanger mounts on my h pipe was broke off. It was causing the h pipe to vibrate on the cross member. I just pried the pipe over and welded in a new mount.
Old May 31, 2006 | 07:28 PM
lookinforastang's Avatar
lookinforastang
I ♥ Acer
could be the PS pump starving for fluid or the belt is lose
Old Jun 1, 2006 | 03:25 AM
silver91gt's Avatar
silver91gt
it is also possible your inner or outer tie rod ends are going bad.
does your steering wander sometimes?
Old Jun 1, 2006 | 03:29 AM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
could be all of that AND a rack squeek from your rack boots, could be a strut issue...but it is probably nothin to worry about. if you want to get rid of it get a spray can of grease or silicon and spray your bushings down.
Old Jun 1, 2006 | 03:31 AM
88BlueGT's Avatar
88BlueGT
I also thought it might be power steering but that would make that noise wether he turned left or right......
Old Jun 1, 2006 | 03:32 AM
FiveLiterRiceEater
yeah but ford's pumps suck anyways so im sure that will start makin noise soon
Old Jun 1, 2006 | 03:34 AM
88BlueGT's Avatar
88BlueGT
Yea, sorry for the hijack but why the hell are new ford pumps sooooooooo loud. You can barely hear youself talk over them for the first 500 miles or something like that.... is it just part of thier break in period or something?
Old Jun 1, 2006 | 04:03 AM
lookinforastang
I ♥ Acer
mine is actually pretty quiet
u can hear the pump starving at full rotation, 2.2 turns on foxes (14.7:1 quick ratio i think???)
Old Jun 1, 2006 | 04:06 AM
88BlueGT's Avatar
88BlueGT
Have you ever replaced it?
