Check engine and off road H Pipe
Old Apr 16, 2004 | 10:31 AM
mustangdave357's Avatar
mustangdave357
Default Check engine and off road H Pipe
I have a 1995 Cobra and it has a off road H pipe Installed, would this cause the check engine light to come on from time to time and then go off again? It comes on for about 30 seconds to 1 minute and goes off again. Comes on maybe every 30 minutes or so then goes right back off, Thanks, Dave
Old Apr 16, 2004 | 11:02 AM
95stang's Avatar
95stang
Default RE: Check engine and off road H Pipe
Have you tried pulling any codes? If there's an Autozone near you they'll pull any codes for free. I believe yours has the OBD I so I don't believe it would exactly be coming from having an O/R h-pipe. Did you happen to change the O2 sensors?
Old Apr 16, 2004 | 12:24 PM
mustangdave357
They told me they could only pull codes if it stayed on all the time.
Old Apr 16, 2004 | 02:41 PM
roundman's Avatar
roundman
from what I've read about the OBDII system, it could the the off road pipe as the OBD system is a lot more sensitive than the EEC IV is, but that's about all I can offer you.
Old Apr 16, 2004 | 02:43 PM
roundman's Avatar
roundman
forgot to mention you could try the Ford tech line at 586-468-1356 and see what the guys there think it could be also.
Old Apr 16, 2004 | 02:59 PM
619socalstang's Avatar
619socalstang
ORIGINAL: roundmanracing
theese guys at the ford tech line are pretty sharp all noods this is a number you need!!!!!!
Old Apr 16, 2004 | 07:35 PM
95stang's Avatar
95stang
My CEL kept coming off and on but they were still able to pull the codes. I still think that '95's were the last year of OBD I. They have both diagnostic ports, 1 under the dash and 1 under the hood. They pulled my from under the hood, back passenger corner behind strut tower.
Old Apr 30, 2004 | 02:06 PM
93payupGT's Avatar
93payupGT
First of all its OBD 1 technology. Autozone can only find a problem if the light is on at the time of scan. sounds to me like a egos problem. You can order from summit racing a egos MIL blocker thingy??? it is about 60 bucks i think.
Old Apr 30, 2004 | 02:14 PM
mustangdave357
MIL blockers are only good for the '96 and up models with the 4.6. The light is off, I think it was coming on because of a misfire. There was a lot of water in the gas tank from the car sitting. It runs better every day.
Old Apr 30, 2004 | 03:57 PM
95stang's Avatar
95stang
Glad to hear it's running better. If the CEL keeps coming off and on. You can get a scanner at Wal-Mart or parts store for like 25-30 bucks (that's what I did). Or you can use a volt/ohms meter.
