HELP! Fuel tank leaking....
RE: HELP! Fuel tank leaking....
Thanks for the advice and part #. I have one on order from Ford Japan, it will be here on Monday. Unfortunately the gas tank is full right now and my syphon didn't work to pump out the gas.
ORIGINAL: 5.0 MPG
I have the same problem and used some gas tank filler from autozone and it worked, just use up most of your gas before you apply it. I have one on order from CJ's
CJ Pony Parts at 1-800-888-6473 Part# FPS4
mrappe
09-26-2015 10:16 AM
