Window motor??
Cali, but it doesn't matter I'm at work I don't get out till 8:30, but I have very bright lights when I get home
ORIGINAL: PRO50SC
Today? Where are you. It's night here.
ORIGINAL: PX429
ORIGINAL: PRO50SC
No guys it has nothing to do with the window motor at all. I just fixed my dads motor today bc it did the same thing. Take the door panel off the car and then unbolt the 3 bolts that hold the window motor in the assembly. There should be 1 screw that hold on a plate when you take off the plate there is probably a big mess of grease and chopped up plastic bushing in there. Go on ebay and get a window bushing repair kit. You have to replace the bushings in the gears to make it work right again
you sure cause i could pull the window up or down freely?
by the way guys thatnks for your help.
ORIGINAL: stanglx2002
its common for those little cheap plastic bushing/gears to go out.
http://www.latemodelrestoration.com/...gory=M7MOTGEAR
http://www.latemodelrestoration.com/...ory=MABRUSHGEA
http://www.latemodelrestoration.com/...ory=M5GUIDEBUS
http://www.latemodelrestoration.com/...egory=M6WINMOT
those are all the little parts you should possibly need none of its very expensive.
Thanks!
ORIGINAL: r.barn
logan409
Sep 26, 2015 07:43 PM
