koeo codes
Old Jun 4, 2006 | 03:46 PM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
Default koeo codes
where can i check to see what they are? the corral deal isnt working for me
Old Jun 4, 2006 | 03:55 PM
FiveLiterRiceEater
Default RE: koeo codes
nevermind i found something.
but i got a code 96, which is an AOD trans code...i have a t-5 ?
Old Jun 4, 2006 | 05:09 PM
TENGRAM's Avatar
TENGRAM
ORIGINAL: FiveLiterRiceEater
which mode did you get that in? with car running(koer)? or off(koeo)? or was it koeo after the seperator pulse (continuous memory code)?
Old Jun 4, 2006 | 05:10 PM
FiveLiterRiceEater
koeo memory mode. it flashed 11 ... 11 ..... 1 ..... 33......96.....33....96
the 33 is a EGR code, which i'm not worried about cause its not functional anyways.
but the 96? why an AOD code in a t-5 car?
Old Jun 4, 2006 | 05:13 PM
TENGRAM's Avatar
TENGRAM
if koeo or cm then 96=Fuel Pump Circuit Open-Battery To PCM
have you tripped the inertia switch in the back under the trim panel? if so, that would cause 96 in cm. let us know
Old Jun 4, 2006 | 05:16 PM
TENGRAM's Avatar
TENGRAM
ok, 11 11 means no koeo "hard faults" 1= seperator pulse,
33=you know that one
96=what i mentioned previously
here is one of the places where i check my codes http://www.troublecodes.net/Ford/eec-iv.shtml
Old Jun 4, 2006 | 05:23 PM
FiveLiterRiceEater
ahahahha i'm a dyslexic ****! i got 96 and 69 mixed up when looking at the codes [:@]
so if i have this open circuit between my battery and pcm, my car is still going to start right? i just drove it 5 minutes ago and i check the codes on it an hour ago? and if this is a memory code, does that mean its an old code?
Old Jun 4, 2006 | 05:36 PM
TENGRAM's Avatar
TENGRAM
memory codes are from all driving since the last time the ecm was reset (battery disconnected for ~10 minutes)
they may not represent what is currently wrong with the car, only something that was wrong. suggest that you reset codes
drive it a day (or at least a little bit) and then recheck the codes to determine if this condition is still present.
Old Jun 4, 2006 | 05:56 PM
FiveLiterRiceEater
ok. sounds good. the last time i had the battery disconnected was last weekend when i did my battery relocation. but it hasnt had any no start problems..or any problems really, besides it smoking really bad.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
