I have problems need HELP
RE: I have problems need HELP
mabye the rubber hose between the pump and pickup isnt tightened down tight enough.
I would get the regulator replaced on warranty, and if it doesnt fix it, then something is wrong with the pump.
another thing you might want to check is the fuel filter.
it might be clogged restricting the flow.
do the easiest first.
the fuel filter, if it doesnt work then the regulator, then the pump.
yes, but what exactly are you doing to change the pressure,
there should be a bolt with an allen head in it, and a nut on the bottom.
the nut is just to lock your adjustment.
you need to loosen the nut to adjust the pressure by turning the bolt.
I installed new pressure regulator , new 255 pump, put back my 19lbs injectors with my MAS 75mm. Now i am having a problem that my fuel pressure does not come down from 49lbs. What can i check for.?????
Hey Adder, a little rough on the guy don't you think?
ORIGINAL: AdderMk2
so lets see... you took your base fuel pressure and decreased it....
WHAT ARE YOU.. STUPID!!!!!!!!
