Grinding noise in rearend...
Old 06-07-2006, 01:53 AM
ho85GT
ho85GT's Avatar
Default Grinding noise in rearend...
I have a grinding/ squeal noise in my rearend that only seems to happen when taking corners after driving for 25 or so minutes, could this be a bearing?? It doesnt seems to be the brakes or tires rubbing on anything.
ho85GT is offline
Old 06-07-2006, 04:33 AM
schwindty
schwindty's Avatar
Default RE: Grinding noise in rearend...
Check the drums first off as thats a easy fix make sure the pads are not draggin anywhere or are not super worn out.....if thats not the problem you have a bearing going, more than likely a wheel bearing are you sure its coming from the back?
schwindty is offline
Old 06-07-2006, 03:46 PM
eaturls1
eaturls1's Avatar
it could also be the limited slip clutches going bad
eaturls1 is offline
Old 06-07-2006, 04:02 PM
PX429
PX429's Avatar
Or Your Muffler Bearing Are Going Bad
PX429 is offline
Old 06-07-2006, 05:46 PM
ckyguy68
ckyguy68's Avatar
dont even get started on that one....
ORIGINAL: PX429
ckyguy68 is offline
Old 06-07-2006, 06:09 PM
Scout2232
Scout2232's Avatar
You don't have a trac-lok do you? *cough* Garbage! *cough*
Scout2232 is offline
Old 06-08-2006, 01:46 AM
ho85GT
ho85GT's Avatar
Im sure its coming from the rearend and pretty sure its not the drums since i have 4wheel discs and yeah i have no trak-loc . I was thinking the bearings but wasnt sure, it only does the sound when taking a corner.
ho85GT is offline
Old 06-08-2006, 01:59 AM
schwindty
schwindty's Avatar
This is odd usually when bearings go you can start to hear them gradually all the time not only in corners........TAke the diff cover off and have a peek at the carrier
Old 06-08-2006, 02:07 AM
ho85GT
ho85GT's Avatar
I already have i dont notice anything unusual....i dont have much knowledge abouth diffs or what to look for. could the pads (for the discs) slip nad make the noise to???? im about to take it to a shop and have them rebuild it... i just dont want to pay for labor.
ho85GT is offline
Old 06-08-2006, 02:17 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
time to upgrade to an 8.8 just pirate ur brkes and axels off the 7.5 it will swap over!
rmodel65 is offline
Quick Reply: Grinding noise in rearend...
