Air Conitioning
Old Jun 7, 2006 | 08:29 PM
  #21
Bad Karma's Avatar
Bad Karma
Default RE: Air Conitioning
Jeff, It could mean either I suppose....
From the sounds of it, the switch is bad. Especially if the gauge is reading overfilled by his readings.
I've always taken the trick as a shortcut to finding a bad switch. 90% of the time it is and that's all that the customer needs.
We cheat at work, we have books AND tools to help us do the job.
Most of us "roots/backyard Mechs" don't have but a half set of Craftsman tools that Uncle Jesse gave us way back in the day.
I'd replace that switch.
Good luck,
-Ivan
Old Jun 7, 2006 | 08:51 PM
  #22
Frebius's Avatar
Frebius
Ivan, maybe I am confused on this one. You said if the switch was bad that the clutch would not come on right? Well if that was the case the compressor would not even spin would it?
ORIGINAL: Bad Karma
as far as testing the LP switch...
again, if the clutch is coming on then you shouldn't need to do this at all...
Unplug the harness going inot the LP switch. Should be a two wire deal, nothing serous.....take a paperclip and bridge the two wires going into the harness, not the actual switch which you just unplugged from. If the AC Compressor kicks on now (engine running mind you), then you have a bad switch....$27 at any Ford house. Easy to install, but you may lose some R134A Freon.
If bridging the switch does not work, then it may be an electrical issue of the switch inside your cabin (the actual AC switch on the HVAC controls) or that there is no/not enough Freon in the system....
If that's the case, then you have a leak and the only way to nail it down would be to have a professional do a Dye leak check for you....most places around here charge $39.99 for the actual check but it's money well spent unless you have a UV light and dye
Keep us posted.
Thanks,
Ivan
Old Jun 7, 2006 | 08:54 PM
  #23
jzgt's Avatar
jzgt
Thanks Ivan. That's kinda what I thought and you're probably right -- the switch is an easy item to replace and is relatively inexpensive to buy so it doesn't really do any harm to give it a whirl. Thanks for the clarification!
- Jeff
Old Jun 7, 2006 | 08:56 PM
  #24
Bad Karma's Avatar
Bad Karma
If the switch is bad, there is no way the clutch will engage against the pulley on the AC Compressor. If you have a clutch that is "grabbing" onto the pulley on the AC Compressor, then let me know. The switch could be working if you added enough freon earlier.
Did you add any Freon with the kit you got today? What is the reading you have on the dial if any?
-Ivan
Old Jun 7, 2006 | 08:59 PM
  #25
Frebius's Avatar
Frebius
I did not add any Freon just used the guage and it came in at 55 Psi.
Old Jun 8, 2006 | 09:35 AM
  #26
Frebius's Avatar
Frebius
I am not sure what is wrong but it is definitely getting old driving with no AC
Old Jun 8, 2006 | 01:45 PM
  #27
ikeybmg's Avatar
ikeybmg
+1, i feel ya man. mine dont wrok either. and its hot around here! when i turn mine on, i cant feel it kicking on. and nothing but hot air![:@]
Old Jun 8, 2006 | 03:38 PM
  #28
Bad Karma's Avatar
Bad Karma
What is your AC Compressor doing? Is the clutch engaging??
55 psi is way high.
-Ivan
Old Jun 8, 2006 | 04:08 PM
  #29
Frebius's Avatar
Frebius
The AC unit is turning off and on so I would assume it is.
Old Jun 8, 2006 | 04:20 PM
  #30
Bad Karma's Avatar
Bad Karma
ORIGINAL: Frebius
Ok, so the clutch comes on ang goes off with the activation of the switch inside your car?? If this is the case, there are some issues that will probably need some professional help. You might have a clogged compressor orifice screen (not a big deal) or your compressor itself could be dying (****ty) and not doing it's job correctly of compressing the Freon.
Either way, it wouldn't hurt to take it to a reputable shop. You might even be able to find a reman compressor if that's what it ends up being.
Now, if it's turning on and off with you not doing anything, than that could end up being a better thing. It would definitely be the LP switch. I mean, if you have the car running, calling for air (AC ON in the cabin) and it's cycling between clutch engagement and disengagement, then replacing the LP switch would cure the issue.
-Ivan
