wheel and tire help
Old 06-07-2006, 12:51 PM
jagman454
jagman454's Avatar
Default wheel and tire help
Ok so i finaly found some wheels i want, but they dont come with tires... i have a 1990 GT and i'm not sure what tires will fit on my car so there will be no rubbing problems... here's the link to the tires they are 17x9 thanks...
http://www.stage3motorsports.com/product/S3M4CR179
jagman454 is offline
Old 06-07-2006, 01:09 PM
Racesmith
Racesmith's Avatar
Default RE: wheel and tire help
I have 17X9s on my 90. I have 245/45 all the way around. My car is lowered 2". If your car is lowered I would suggest something smaller for the fronts...like a 235/45. My two cents.
Racesmith is offline
Old 06-07-2006, 01:10 PM
AdderMk2
Banned
AdderMk2's Avatar
17x9 might give you a bit of a rub up front if the backspacing is incorrect... dont go wider then a 255 up front or you will have clearance issues
Are you running aftermarket upper and lower rear control arms??? if not, you might wanna get some so you can eliminate the quad shocks.. set a 275/40/17 on those rears and something like a 245/45/17 on the front
AdderMk2 is offline
Old 06-07-2006, 01:13 PM
P Zero
P Zero's Avatar
I believe you can squeeze a 275/40/17 no problem in the rear and a 255/45/17 in the front. It MIGHT rub a little in the front when the wheel is all the way cranked to the lock. It should only rub on the inner fender (wheel well), if at all.
-P.
P Zero is offline
Old 06-07-2006, 01:28 PM
AdderMk2
Banned
AdderMk2's Avatar
stick with the 245/45/17 in the front.. its the PROPER tire size
and you wont have to worry about rubbing
AdderMk2 is offline
Old 06-07-2006, 02:08 PM
jzgt
jzgt's Avatar
In 91 they reshaped the inner fenderwells used travel limiters on the rack to account for the 16" pony wheels.
- Jeff
jzgt is offline
Old 06-07-2006, 03:55 PM
7upedition
7upedition's Avatar
go with 235/45 up front, i have 4 lug 17x9 cobra R's on my 90 and 245/45 rub a bit in turns, 245/45 are good for the rear!
7upedition is offline
robcy
Suspension
10-27-2015 11:14 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
10-07-2015 07:02 PM
mungodrums
09-28-2015 05:45 AM
09-08-2015 11:50 AM
Quick Reply: wheel and tire help
