What Do I Need To Do This?
#21
RE: What Do I Need To Do This?
you have the nitrous on before you even let you the clutch? i thought that was a no no. thats what i meant, that intial "pop" is whats gonna bring them up then weither you keep them up is gonna be based on how much power you have.
ORIGINAL: Sprayin86
I spray mine right off the line as do many others on here.
ORIGINAL: DriftVic
i aggree slicks and good suspension and clutch will prolly pull an almost stock cars front tires up. there was a guy running at our local street drags(front straight of the local 5/8th short track) and with slicks he could just barely lift them on a 4.6 with nitrous, but your not gonna launch with nitrous anyways, and a trick suspension.
#22
ORIGINAL: myshifter
a proper 12 second car will do that, most people have no idea about suspension geometry, all they want to know is what size injectors, H/C/I, MAF blah blah blah
#26
My Mustang II in my sig has a couple of pics where you can almost see light under the tires but thats with some S#&ty Napa shocks that was on it i put koni drags but aint run it yet it has ladder bars 32x14 slicks and 5.38's
#27
well a more intellegent answer would be to make a form behind the rear axle centerline and then pour concrete in there rather than cinder blocks which are are mostly open air pockets:-P
ORIGINAL: ckyguy68
can i get a somewhat intelligent answer please?
ORIGINAL: gr84u
put a whole bunch of cinder blocks in the trunk...
